Frank Patten
- Jun 26, 2005
- Location
- Worthing
- Website
- www.frankpatten.co.uk
- W212 E class 220cdi, R171 200 SLK
Hi All,
W210 220cdi 2002 Estate
Recently I was overtaking at about 60mph when I pressed the accelerator through the kickdown and got reduced acceleration and no changedown of gears. At the same time the display showed "EPC" I have since experimented and I find that if I avoid kickdown I have normal full performance. The EPC fault only occurs during kickdown. If I kickdown above 90mph the car actually slows down but above 100 it behaves normaly and accelerates up to 120 or so. Perhaps this is because the speed is above the point at which the gears would change down.
This looks to me to be similar to the brake pedal switch problem where a sensor in the switch causes a computer fault, but before I attempt to change the kickdown switch I would appreciate some input from you guys please. Where does the fault lie?
