W210 Air con no temperature adjusment?
Nick66
SW London
W210 E240 2000
On my year 2000 W210 E240 with manual air con I can not regulate temperature with rotary dials,it is all ice cold for first two thirds of the adjustment,then tepid.Any ideas?
Duo-valve might be gummed up solid
N
Nick66
SW London
W210 E240 2000
Thanks,I will check it out,I have a spare duo valve from my scrapped 98 E320 if I can find it...Another issue I have is the illumination on passenger side of the dashboard stopped working,around passanger rotary wheel for temperature and around that area,is there a fuse controlling only that side of dash,or bulb needs changing?
I think it's small bulbs in there IIRC
N
Nick66
SW London
W210 E240 2000
Any idea what type of bulb?
N
Nick66
SW London
W210 E240 2000
Does the bulb sit in the temperature adjustment wheel,one with red and blue markings?
N
Nick66
SW London
W210 E240 2000
Ha,found the bulb,on the fan speed control knob,already managed to break the white plastic tab covering the bulb...now to find the tweezers...
N
Nick66
SW London
W210 E240 2000
Duo valve seems to be moving smoothly,electrical connection and wires seem ok.It seems I will just have to wear warmer clothes while air con is on
N
Nick66
SW London
W210 E240 2000
Regarding the bulb it seems to be t 286,wedge type with cap.Ordered from eBay,so we will see..
N
Nick66
SW London
W210 E240 2000
Bulbs arrived,managed to fit it,still no light,might have to check fuses...
