W210 Automatic transmission
Safwan_algwarsha
New Registration
W210
I have a w210. When I put the transmission in R to go in reverse, then I put it in D, the car moves forward but does not change gears. It keeps deliberately at the lowest speed. I cannot increase the speed and the gears do not change.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Check atf level.
malcolm E53 AMG
If the ATF level is ok it sounds very much like the speed sensor in the electric plate is playing up you do need to get the fault codes read to be certain it could be any number of things with a car that age
brandwooddixon
Wolverhampton
S63 Coupe 2014
It sounds to me as if it's in limp mode. This will restrict gears to reverse and 2nd gear.
As above, check fluid levels, but after that likely an issue with the electro-plate (internal to gearbox). It could be as simple as debris blocking a solenoid, in which case cleaning and new a fluid change may be all that is needed.
If I recall correctly when checking codes you'll need to connect to the diagnostic socket under the bonnet for the gearbox and engine management (its a round socket).
