E300estate99
- Apr 10, 2007
The rear OSR door lock on my E300 estate has failed and I've got a replacement for it.
However, for the life of me can I remove the old one (the inner door panel is off and all the screws removed). It seems as though I need to remove the outer door handle to enable the inner plastic "back plate" to come out, which will then allow the old lock to slide out. Sadly, I'm struggling to work out how to take the door handle off!
Can anyone give me a steer on the steps needed to replace the lock, and whether or not the handle does need to be removed to get the lock out. Even help on removing the handle would help.
Thanks.
Thanks.
