W210 Door Trim removal
robs-mbz
Newcastle under Lyme
1997 E300TD
How do I remove the door trim/bump strip on the door of my W210? Does it just un-clip or do I have to remove the door card and work from the inside?
Ellsy Tanners
Mars
Hello,
there is normally one screw on one side, i think at the frone which can be undone with the door open. then it slides off. 99% sure you dont have to remove the door pannel
robs-mbz
robs-mbz
1997 E300TD
Thanks Fella's! Hope you are right and the trim just slides off, don't fancy removing the door card! Will give it a try at the weekend.
I believe that they have keyhole slots, side ways on, I hope so
