w210 e320 c.d.i
sms78
Northhamptonshire
w210 e320 c.d.i , Vw Beetle 1303
Hi ladies and gents .
I want to change the oil and filters on my beast this weekend does any body know exactly how much oil the engine holds with a filter change as i dont want to put too much in :eek: Also has anybody experienced an annoying water leak from the heat exchanger assembly on the left hand side of the engine before ? It looks like a lot of bother to strip it all down to me and mercedes wanted 300£ for a new one! I Think its some sort of rubber seal that fits between the two parts . I fixed it before by putting some additive in it which has lasted 8 month but now its leaking again :mad:
Myros
R107, S211, R170, C219
I think it's 7.5 ltrs
Definitely in that ball park. I suggest put 6.5 in, and then work from the dipstick, 250 ml at a time. Get it to the bottom mark, run the engine , check for leaks, shut off and check again on the stick. You'll find the filter will have swallowed some up. Remember final stick check when fully warm
sms78
Northhamptonshire
thanks ill try it like that
