maxwil
HELLO EVERYBODY I am new to the site and very impressed with your responses. I have been reading all your threads because I have a problem.
It all started with the ABS/esp lights showing and the car running cool ( about 55) . Glow plug light remaining on after start.
The answer from your threads was Glow plug, Foot brake switch and Thermostat housing replaced. I collected the car ,gave it a run and stopped at the local shop - For it to refuse to start- found Pressure regulator valve had stuck open. Valve replaced.
The following day my starting problems began. Upto this point car started instantly ( done 65K) Then we had all injectors serviced and re-sealed.
My problem is now still a long wind-up before start. I have also replaced glow plug relay.
Since valve and injectors sorted the car litterally flies and on run is turning about 40mpg.
Any suggestions on what to do next would be appreciated.
