W210 E320 Water leaking into plug 6
johnemery5
Near Chard Somerset
www.westerngarage.couk
1994 E320 Coupe Sports Chassis Black AMG Alloys
I have an E320 1996 N W210. I had a missfire and on investigation I found that No 6 plug (nearest the bulkhead) was full of water. Dried it out and all was fine. On removing the coil cover it was clear that the threads had beed stripped as it is very difficult/impossible to tighten it down. Additionally, it looks like that when it rains, the area below the windscreen wiper doesnot seen to have any means of stopping water from getting onto the rear of the engine. Dont know if this is correct.I have had to try and seal the cover down using clear silicone, not ideal and doesnot last long. Any help or ideas would be appreciated. Thanks!
Xtractorfan
S class
Is it possible to fit a shield below the wiper / scuttle panel to direct the water away from the engine, you could also consider fitting the shield to the engine..
jibcl500
Cambridgeshire
CL500,ML55,SLK280
John
theres a rubber drain hole that blocks up with muck and the water starts to over spill have a look around the bulkhead. therses also one on the underside of the bonnet. If local to haddenham drop in cb6 3ul
jib
