Bluegrass
- Aug 17, 2005
- W210 E320 Avantgarde 2000
I was doing a pre MOT test check myself and noticed that on my W210 Estate the N/S/R fog lamp works and not the O/S/R which is strange as this is the one that should work in the UK.
So I changed the bulb and still nothing.I'm going to connect them together so that both work.
Just a quick question.What is the correct method of removing the rear light cluster?
I undid the two 8mm nuts and twisted it out but it's a bugger to re fit as it's very difficult to slot the clip in then tighten the bolts.
Do I need to remove the tailgate trim?
Edit/Delete Message
Edit/Delete Message
