whammer007
- Nov 8, 2005
Hello all,
This morning it was particularly foggy, so I turned on my rear fog lamps only to be greeted with a bulb error on the dash.
I changed the bulb first of all, still the same. Then checked the fuse on the o/s of the dash, it was intact.
There doesn't appear to be any power getting to the bulb holder, which leads me to believe that it might be wiring or a relay at fault.
I was wondering if this was a common fault on this model, ie if you look at xyz you will probably find it is corroded etc.
Does anyone know if there is a rear fog lamp relay, or if the rear fog lamps are common to any other circuit.
Before I start digging around a bit deeper, I thought I'd ask you peeps on here.
Regards,
Col
Regards,
Col
