robs-mbz
- Dec 9, 2006
- Location
- Newcastle under Lyme
- 1997 E300TD
The heater blower switch on my W210 has developed a mind of its own, sometimes the speed of the fan doesn't correspond to the setting of the switch, its either too slow or too fast. Ive noticed that if I push or pull lightly on the switch, normal service is resumed! The fault only seems to effect the firs (most often used) three speeds and I am guessing that its just the switch at fault. Before I start to strip it out, has anyone come across this problem before, how easy is it to remove the switch, can it be repaired or is a replacement switch required? Any assistance would be much appreciated!
