W210 'Key'
ShinyF1
SW London
Contemplating my next
My spare key now only unlocks the car, but will not operate the ignition.
Any ideas? Or is replacement required??
Leave it in the ignition for awhile (overnight if possible) and it may re-sync again
Sorry to but in here, on the last thread we had with the EIS lock the fault is caused by leaving the key in and it should not be done. This is MB info
Malcolm
Was that not both keys not working?
I know what you posted has been done, but it was during the post on Friday that I read this. when the key is left in the lock a small current flows and it could be the heat that builds up, but on the other hand the key does stay in the whole time that the engine runs. I do not know more.
Malcolm
the info was for cars with EIS ignition key
Ok, I would look at it this way. If the EIS is on the way out leaving the key in would not do much damage as it is likely to die anyway. However if it is just a re-sync issue then leaving the key in should fix it.
However it is not my car so ShinyF1 will have to decide his best course of action.
You have a good point there young man:D
malcolm
Thank you, I think I will leave it there for this evening. Monday morning is rapidly approaching.
Parrot of Doom
Manchester
heh, I'd pull a wheel off if I was you, just in case :)
