Hi my 210 Estate sproadically refuses to start. Its as if the immobiliser/alarm has been trigged and the fuel is shut off. fiddling with fuses and pulling them in & out, seems to reset things and soon after say 20-30mins its starts again as if nothing was amiss - runs for a few weeks then you play Russian Roulette whenever you get in the car - the car has also start to stall leaving me stranded in the road unable to move blocking traffic etc.
I had car towed to indie in Cheltenham who hooked it up to his pc and found that the following fault:
EIS - electronic ignition switch ELCODE
MB number: 2105450208
Code B1059 - Faulit in CAN comm with control unit N10/1(Signal Aquisition & actuation module (SAM) driver side.)
the man duly removed the unit sat it on his desk and tried to order one. couldnt straight away so replaced in back in the car. The car fired up first time & he warned me it could happen again at any time.
I then had to be 350 miles away on holiday with all my family in a field when again it refused to start. I rang the man in cheltenham - he flatly refused to tell me where the unit was located so I could attempt his temporary 'fix' to get me & my family home... he refused to tell me. luckily for me it started after yet more fuse twiddling and now I am keen to replace this unit - (RRP GBP 200+vat) or breakers..
I need to know where this item is and what I need to remove to replace it etc
have any of you come accross this starting issue before or have a clue where I might start looking for the N10/1 SAM unit?
thanks for your help in advance.
JCG
VIN 2102652B082670
JCG
VIN 2102652B082670
