AdrianDW
I have a 2000MY E240, 71k on the clock. Was checking the tyre pressures yesterday, and the NSR tyre appears to be worn almost to limit, whereas the identical OSR (same make, on at same time) has about 3-4mm left before it needs doing. I've done the "bounce" test, which seems ok, and on a 100 mile run this morning there's been no signs of vibration or odd noises which would suggest a problem
There was one little dribble of slightly oily fluid on the carport floor last week (less than a dessert spoon worth), but having jacked it up and checked I can't see any obvious leaks around the brakes or suspension.
I'm guessing this is a suspension problem, but am baffled, and would appreciate any thoughts from the floor please?
