What model is it, can you put up first 6 numbers of VIN 210---aa1 said:Bought the car privately on friday, sunday srs light on, dealer says unit seems to be frozen but does not know why, cost of new unit £355.00 and does not know if this will cure the problem. any ideas?
television said:What model is it, can you put in the first six letters of the vin no 210---
malcolm
When cleaning the car have you accidentally switched off passenger bag.if fault still there, do a reset as Jberks says by disconnecting battery for 5 mins. If still no joy, there will be a fault code stored it could be anything from a seatbelt sensor up. There is an issue with over sensitive retracters for the side bags, but I thought that it would have come to light before now. A fault read out will be the only way forward if the re set fails to work.aa1 said:the vin no is as follows 2102262B42---- hope that helps aa1
You will have to get the fault codes readout and cleared by MB or a indie with a HHT test set.aa1 said:Did the lock to lock and that fixed the other lights but the srs light is still on, how do I find out the fault code? regards aa1
tjo said:Hi aa1 in my experience the most common srs problem on 210s is the seat recognition pad, the wire breaks just as it comes out of the pad
