davidash
I own a 1999 w210 E280 with 137000km's on the clock. It has been driven mainly on highways and city roads. I recently had to replace the front shocks, front lower ball-joints and the anti-roll bar drop links.I now have a knocking sound from the fromt right when driving on an uneven surface, such as paving.I can sometimes replicate the knock by pushing the front right of the car down. The agents suggest that the upper contol arm ball joint may be worn and I gather this is fairly expensive.I have read a fair amount about the anti-roll bar bushes also being a problem on the W210. If all of these components have failed, then all that is left intact is the coil spring! Has anyone else had similar problems?
