Chris Frost
Hello chaps,
Noob here so I've been soaking up some knowledge from past threads for the last couple of days before posting my first question
My E320 CDI (WDB2100262B421182) is on a 51 plate and it's developed the BAS/ABS/Limp Home Mode problem. On top of that the battery isn't holding charge; but I think that is a separate issue. The car wouldn't start even jumped from another. (New Bosch 019 100Ah 460/800 due tomorrow)
Reading up here it looks like there are two possible causes -
1) the brake light switch
2) a lose connection causing problems with the ECU.
I don't know if my diagnosis is right (comments please), but before the car died I had a short period where Limp Home Mode was intermittent. Sometimes travelling down hill the car would cure itself and be OK for a while. Going up hill the problem would return, so I'm thinking the ECU fan is worth a look before I replace the brake light switch.
I've checked the Merc hand book. Not much info there. Can anybody point me in the direction of a good paper workshop manual or tell me where the ECU is located?
Thanks in anticipation.
