W210 Xenon Alignment
Matt_EClass
Orpington, Kent
W211 2005 E55K & 2015 ML350
All, just noticed when driving the car my headlights seem to be pointing upwards (xenons) they seem to be fixed in that position and not adjusting when the car goes up or down, over bumps! It must appear to other drivers I'm driving around with high beam on! Tried switching the lights on and off and switching off the car and re starting it, but no change? Did a search, couldn't find anything.
Anyone got any ideas?
Naraic
2005 CL500.
This happens when the sensor connecting rod on the rear axle breaks. Kneel in front of the offside rear wheel and look underneath, you'll likely see the rod hanging loose.
When the link comes off the lamps usually point to the ground, but it could be a link off the hall sensor.
Xenon lamps normally come on and raise, on my SL they never did, and just came on at the correct height.
I have no pics for the time being of where the links are, you have one back and one front.
If the links are all intact you could set the height manually
Naraic
2005 CL500.
Usually, since we are talking W210, they point to the sky...in my experience.
whitenemesis
CLS55 AMG '05
On the 210 the xenons tend to go skyward when the sensor rods detach, no idea why 'cos they dropped to the ground on the 203...
Even if the links are intact you will need to get on STAR to set them correctly. The zero point must be set and be within tolerance before the position can be confirmed
Naraic
2005 CL500.
Usually because the bottom link breaks and the rod hangs on the sensor...pulling it down as if the suspension was extended and thus pointing the lights up. You can reach under the car and operate the leveling by moving the disconnected rod up and down.
Matt_EClass
Matt_EClass
Orpington, Kent
Oh Buggeration! Just looked under the offside rear qtr like Naraic said and theres a little rod thing hanging down......just my luck!
Is there a DIY fix (I know Whitenemisis said they will need to go on Star) but I havent got time between now and the weekend to get in into the Indie and then at the weekend Ive got to fly to the US on business so it will be well into next week before I can get it looked at.
Naraic, if I give the rod a pull :rolleyes: that will adjust the headlights to get me over the next couple of days?
Thanks all for the help so far....
Naraic
2005 CL500.
I thought it would be that...it's a matter of experience.
I ordered the part from MB (£12) but in the mean time temporarily fixed it...three years later the temp fix is still working.
There is a ball joint. It fits in a nylon bush.I drilled through this and used a small nut and bolt to connect the two.
I had to use a hack saw to take it off though. Good luck.
whitenemesis
CLS55 AMG '05
Try reattaching the rod with wire or something, anything to give the right angle, by trial and error!
If you fit the correct new part it will not need STAR, its dead easy to set if out but i doubt if it will be out
Matt_EClass
Matt_EClass
Orpington, Kent
What a great bunch you lot are! Im always amazed at the knowledge of the people on here....Ill have a go at a temp fix for now (probably Fri as I will be working from home then) Ill order a new part (television, is it just the rod I need to order?)
Thanks all
Naraic
2005 CL500.
Thanks all
I have done this on a W210...it's just a rod, the part number is A 210 328 09 34. It comes with the required nuts.
Just plug and play.
richyba
Ireland
www.4tours.biz
1978 T1 307D,2005 Slk200K,1982 300DSLC (honest!) & 1994 410d Camper
God I love this forum, I was just thinking that my lights were off coming home from the airport late the other night, I looked under the rear just now and guess whats hanging down? Will order the part and stop blinding people!:cool:
