Brian23
Hi I want to change a W211 2005 EClass Estate Steering rack gaitor. I have done this years ago on cars, but on reading how on to, one site it says that you have to drain the steering fluid before you start. Is this correct?
I thought that it would just be. Take the wheel off. Clean the rack area. Unlock track rod end rack nut. Undo the joint nut and pop the joint. Count the removal turns. Remove the gaitor ties and pull off the gaitor. Add a bit of grease to the rack joint. Replace gaitor, retie etc. Anything I have forgotten?? Yes I have jacked up the car etc, before anyone says.
