W211 2007 E320cdi intermittent key not turning issues.
boxer 01
E320 CDI SPORT
Hi all, for a few weeks now I have been experiencing issues when I insert my key into ignition switch to start car, absolutely nothing happens then sometimes if I leave the key in for a few seconds the steering lock can be heard and everything is fine, on certain occasions especially on cold mornings I have to remove and reinsert key a few times before the car will start after this the key will work fine all day. I could use a bit of advice of what could be the at fault. I have been trying to find information online but for my particular model esl and eis problems seem to be rare. I really can't afford to take my car to the dealers so any advice on how to resolve this issue would be welcome.
Stafford71
W208 320 Elegance
My 211 did this on occasion. Started to use the other spare key, all was fine
Sent from my ONEPLUS A6003 using Tapatalk
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Have you tried a new fob battery?
mioba
Nottingham and Köln
I do appreciate you dont want to use a dealer, but how about a merc indy.
I think you would need codes read as something will be showing open circiut. making assumptions on the fault may be more expensive (running round buying parts and fitting them) than having the car looked at (done once).
It could be a remote issue, a relay issue, an EIS issue, a CPS issue so on and so forth.
Where are you based. Someone may recommend if you go
down that route.
mersum1es
Finland
Both keys? if only one, get your key checked, it is working voltage inducted by 'a coil' component (not batteries). Some videos found on youtube...
Could be EIS problem too.
B
boxer 01
E320 CDI SPORT
Hi I have tried both keys and I'm based in Bolton, and I have had codes read but no faults are showing, codes were read by an independent merc. Specialist. I personally think it's the esl sticking as my car has now done 160,000 miles.
B
boxer 01
E320 CDI SPORT
I think it may well be an EIS problem, I think the way forward and easiest option is to remove the EIS and get it tested/repaired, I have seen companies advertising online. Thanks.
