timon
- Apr 13, 2016
- Location
- SW France
- W211 estate 2.2CDI 2003. W140/S320/1998
After changing the conductor plate, oil change and checking the relays, the gearbox works fine. But I had no cruise control, and both ABS and ESP messages and speedo malfunction. So my indy garage changed the speed sensors. All was well for 100 yds when the ABS and ESP etc messages returned. The diagnostics said it was the front offside hub, so we changed the bearing and the speed sensor as the hub plate itself looked OK.
The same thing happened - for 100 yds all is well, then the messages return. This time the Cruise control doesn't show at all on the dash - before it just showed the dotted line.
Could it be an invisible fault on the hub, a fuse, the ABS unit, or a wiring fault somewhere between dash and sensor? I'm at a bit of a loss where to look. Any help gratefully received.
