W211 ABS light
Adamki83
Mercedes E-class, 2005, E270CDI (2.7) + 1992 Mercedes 500SL (R129)
Good evening,
Not having a great day that’s for sure!
got an ABS light come up after not driving the car for about 6 days it’s saying ESP ABS and service brake visit workshop on the little screen in the middle and my cruise control isn’t working.
Plugged into my diagnostic and I’m slightly confused it’s telling me to inspect the distance on either front left or rear right rotor to sensor I’ve put a picture up aswell.
ive done a bit of research and it does say that it could be wheel bearing or wheel speed sensor itself but the traction triangle light is NOT illuminated when the fault is happening.
I have recently had my MOT where the front left wheel bearing had been adjusted could this be causing it?
also as a side note if I clear the code and drive the car above 20mph it’s actually maintaining that speed if not accelerating a tiny bit when my foot is off the pedal it’s really weird and when I brake it feels like the car is trying to fight it but as soon as the light comes back on again the car becomes somewhat drivable.
Any advice would be excellent! My SBC pump is still working as I can hear it.
bertb1
C220 amp sport 2013
Probably a abs /speed sensor
Best plug it in with star at a local Indy
Adamki83
Adamki83
I’ve just checked the live data from the speed sensors and they all seem to be reading my speed ok
bertb1
C220 amp sport 2013
If you get it to an Indy they will be able to tell you
It’s around £30/£50 to plug it in
Well it is at my local Indy
Start it up and drive it forwards going lock to lock with the steering. The warnings may well go.
If they do invest in a battery conditioner
Adamki83
Adamki83
Just tried that, it didn’t work, I’m gonna get it booked in I think I’m hoping it’s just a sensor of some sort!
Adamki83
Adamki83
Rear reluctor rings can give intermittant and unusual behaviour when they break loose. Which they do. Often.
I’m heading to our workshop tomorrow morning and I’m gonna take out the sensor clean it and refit it and see if that clears the issue I think first.
Is there anything I should be careful of?
Could this all just be stuff thrown up by low battery charge from not being driven ?
Decent hours drive first before committing to any work ?
mattkh
England
A160 W168 1999 1.6
It will help to know what type of speed sensor your car has on the rear axle. Some have a reluctor ring, some have magnets built into the wheel bearing.
Adamki83
Adamki83
Battery seems to be in good shape started first time with no struggle at all.
It threw up an error code in Northampton drive it back and around rugby to try and clear it but it didn’t clear (after 2 hours)
I mean it’s almost a 16 year old car and it’s probably original sensors so it would sort of makes sense
Adamki83
Adamki83
I have no idea, I’m hoping to have a closer look at it tomorrow, just didn’t know if I should be weary of anything.
Uncle Benz
West Sussex
Mainly Mercedes
Good luck. The rear sensors are often hard to remove on the w211. The front ones always come out much more easily
Adamki83
Adamki83
I have a feeling it’s the rear, because I have a rotational squeak on the rear left wheel.
One of the wheels that the code reader was telling me.
I’ll let everyone know if I get anywhere
Uncle Benz
West Sussex
Mainly Mercedes
A squeak sounds to me more likely to be a reluctor ring issue.
Adamki83
Adamki83
I’ve given the issue a bit more research and it’s an absolute minefield of things it can be.
But I’ll try and get it out tomorrow, can you clean them up or re seat them at all?
Adamki83
Adamki83
  • #17
Took the sensors out they looked absolutely fine cleaned them anyway looked inside the hole at the ABS ring and you can see it’s actually come away from where it’s suppose to be in places so it looks like it’s going to be that
bertb1
C220 amp sport 2013
Adamki83
Adamki83
  • #19
Just dropped the car off today,
I’m using a little company called H.A Lock in rushden.
I’ve heard plenty of good stuff about them, not going to lie there front yard is probably my actual dream....
20, 30, 40 and 50 year old mercs everywhere!
