Hi everyone! I've did some maintenance on my car. I've had to change the ball joint and the control arm on the front left wheel of the car. This meant, I've had to unplug the speed sensor. After fixing everything upfront, I've connected the speed sensor, and started my car to take a test drive. After a couple of minutes, ABS and EBS lights turned on (never had that issue before). What could be the reason for this? I've also changed one more part, and the alignment got messed up, getting that one fixed tomorrow. I don't think I've damaged the wiring in any way, also I've unplugged the battery when I started working on the car. I've also tried the trick of spinning the wheel to the left and right in order to reset the faults, but it didn't work. What could cause the ABS and ESP lights to turn on? Did I possibly connect the speed sensor in a wrong position?
