W211 airmatic compressor not functioning.
Colin Bleach
w211 E320 cdi
Hi all I am a newbie here and have been unsuccessful searching previous threads which I am sure has been discussed before so I apologise if its repeated. The problem I have is the compressor is not working, I have removed the compressor and bench tested it and is working as it should. The other problem I have is the laminated front SAM sheet is missing from this car, so I need to locate the relay that triggers the compressor if anyone can point me in the right direction please?
AMGeed
Poole, Dorset
S204 C180K
The airmatic relay is in the underbonnet fuse box on the drivers side close to the bulkhead.
In the diagram below, the relay is the unmarked one at the bottom right of the diagram
C
Colin Bleach
w211 E320 cdi
Thanks for your help I will check that out.
C
Colin Bleach
w211 E320 cdi
Ok with some more investigation from the links you supplied I realise I am confusing airmatic with self levelling suspension! my car is an estate and it is only on the rear. So I am back to where the relay / fuse for the SLS may located please.
