W211 Brakes creaking noise
Damoe
NI
2009 E220 CDI A/Garde W211
Hi all
When stopping and coming to a halt, or pressing the brake pedal when stopped, there's a lot of creaking noises from the actual brakes themselves.
Did anyone know what the issue might be or what remedial steps should be taken to address this?
Cheers
D
Sent from my M2007J20CG using Tapatalk
Hi all
Cheers
D
Are they new brakes ? What make are they ?
D
Damoe
NI
Brakes haven't been changed recently. They have just started to creak, and have been doing so for a while. Particularly on the rear calipers
Strip down , clean and add some copper slip to the contact points on the pads ?
pgh13
Nr Leamington Spa
E320CDI 2004 - straight 6 diesel
Are you sure it's not front ball joints? I've had them creaking with the suspension flexing and at times would swear it's coming from the back
Doug1234
Bedfordshire uk
1997 w210 e300td
Do you mean if you sit with brakes on and slightly lift the pedal off they can be made to creak ?, I have been able to do this with nearly all the automatic gearbox equipped cars I have owned .. it’s caused by the brake pads creaking /galling on the discs as the car starts to move forward very very slowly and nothing wrong with it …just the pads friction on the disc… very good trick to unnerve passengers though. I only ever hear the front brakes do it though , I suppose the rears will but do not recall ever hearing them.
D
Damoe
NI
New pads, discs and a rear offside caliper fitted. All cured.
00slk
Cambridgeshire UK
Great news, thanks for getting back with the cure. Helps others in the future :)
DMK/Happy
SE / Coupe / 2003 / C 220/CDI/A
Any harm if a spot of copper grease gets on the disc?
