Rishi Handa
- Nov 15, 2020
- Mercedes w211 2006 e220d
hi all the car is a UK, RHD E220 CDi, W211 2006
The car needed a new battery in the trunk/boot, after changing the windows have some bizarre behaviour.
Nearside front (passenger) window works fine with the switch on its own door. Nearside rear doesnt work at all using switch on the door or the master switch next to driver. Rear offside, drivers side, doesnt work either with any switch too. The switches on passenger, and both rear doors you can see the orange LED illumination on the switch. On the driver door the illumination on the switches are not present, none of the switches work even on the passenger door which is the only window that works using its own switch.
Fuses are fine, electric mirrors, electric seats and all other electrics are fine. OBD scan showing no faults.
Im wondering if the drivers side switch is faulty, and if it was would this cause this behaviour? Can anyone help me...or give opinions of what i should check next thank you.
HELP!! x
HELP!! x
