pcman_jh
- Apr 11, 2003
- Location
- Haddington
- 2013 E220 Cabriolet
My 2004 E220 CDI has just started blowing cold air - all other functions are fine i.e. it increases the fan speed thinking the car interior is not heating up fast enough, but not clever enough to know it's only cold air blowing through. Air con off/on doesn't make a difference.
I see there are threads all pointing to the Duo valve, but if it's 'Duo' surely only the only side of the compartment (his or hers) would be affected unless I'm unlucky and both have stuck at once? Also I see they tend to stick in the hot position, mine's is cold.
I've also read it's not an easy job to get to the valve, does someone have a worksheet or notes.
And lastly, is the Duo valve on this model (W211 not W210) something that can be opened up and simply cleaned?
Thanks in anticipation.
