motocod
- Oct 10, 2012
- Location
- Devon
- W211 E270 2005, ex W124 300CE 1989
Hi Folks,
I have a 2005 W211 E270, which has a leaky washer fluid issue. Seems like there could be some problems with rubber bungs failing on the tanks - just wanted to see if anyone else has experienced this on a W211, and what the fix is? Looks like it might be tricky to get at - presumably behind the wheel well liner.
I get the low level warning, top it up using the convenient hose in the work car park, drive home, and the next morning I look out and see a trickle of water across the road! From what I can see it leaks into the undertray and then onto the ground on the offside.
Any tips or advice would be appreciated - thanks in advance!
Nik
Nik
