james2747
- Jan 26, 2011
- Location
- Newent, Gloucestershire
- E270 CDI 2003
Had a number of jobs to do on the car.
Replacing the front flexi brake hose .... and bleeding brakes all round plus removing headlight to fix adjuster screws, so thought it wise to disconnect both the main battery and SBC battery before I started. Have disconnected both batteries in the past to recon them using a smart charger and had no problems.
I made sure car was unlocked before disconnecting battery.
All went well till a few hours later, I wanted to get in the boot to re-connect the main battery.
I was expecting just to use the standard metal key in the boot lock ... as I'm sure I've opened it that way in the past.
NOT THIS TIME. Nomatter what I tried the boot lock just wouldn't open .... key turns 90 degrees but seems if that is dead locking it rather than trying to unlock it. The lock is in good condition, gets a squirt of WD40 a few times a year so its deffo not seized.
Is there any way I can get power back to the car without opening the boot .... I'm sure some cars have a +'ve and earth connection under the bonnet where you would connect up a charger. so I could then try to get it to unlock by pressing 'unlock' on key fob
Failing that, is there any other way I can get the boot open?
