W211: E320 cdi -wipers, where do i buy them and how do I replace them
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
perhaps a silly question but where do i get replacement wipers for the car and more importantly how do i replace them, they don't look anything like the ones i've had on all previous cars (clip on), but instead are like long strips of rubber,
are they easy to replace ?
Yes dead easy they just come off the pegs on the arms, known as aero blades.
The Valeo versions are very good.
It tells you in your handbook how to change them
V6Matty
Newark, Nottinghamshire
they are ever so easy to replace, and from memory they also just clip in/push in. I bought mine from halfords although that was only because i was buying a few things from there and there was an offer on wiper blades.
DY2
Bexleyheath, Kent
W211 2003 E320 Cdi Automatic
I replaced using Bosch wipers... but they squeaked after a while.
So I went to the dealer... little more expensive, I paid £32.. but so far they are completely silent on the screen, and the best replacement pair I have used.
Very easy to replace...
- Turn the key to position 1 or 2
- Turn on the wipers, and when they are vertical on the screen, switch off the car.
- Lift them up off the screen, then you'll be able to turn the blades 90 degrees away from the glass, and then they just pull off the peg.
- Put on the new blades, turn them back towards the screen, then back down onto the glass.
About 2 minutes :)
For people in the UK Halfords do sell some good blades cheap, I have done well there too in the past :D
The advantage with this type of fitting is that you do not have to pull the arm back as far as you do with the old system, the system is much quieter as less moving parts.
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
ok i bought a new set and they were easy to fit once i figured out how to get them off,
so here's some photos to help the next person looking to do it
Pleased thats all done Niall, It is said that it is better to see what you crash into, as it takes the shock element out of it ;);)
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
yeah i replaced the wipers due to smears on the screen when its wet and.... same problem with the new ones
so feeling kinda peeved, what can I use to clean the windscreen of smears/smudging when wet ?
T cut is perfect to remove all grime,,, do wash you washer tank out at some point in time.
I have just used T cut on my CL500 as that had got bad,,its fine now and crystal clear
SQ_W211
W219 CLS55 AMG
T cut or any paint cleaner should sort it out.
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
i don't have any t-cut, you say paint cleaner, what could i use for that (they don't sell t-cut in Sweden)
I fine cutting paste is all T cut is, you cannot damage the glass, haze remover something like that will do the job.
You must be friendly now with a body works :rolleyes: ask them for a little polishing compound
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
well even though they fixed my car i'm not friends with them, they are just a dealership,
still i guess i can try and ask around, i've tried window cleaner and it didn't help, i'll take a good look in my outhouse this weekend and see what i can find, would 'lack knafta' help ? (paint thinner ?)
Läck knafta (turps) has no abrasive qualities, window cleaner could make the problem worse, it made mine worse last week and I used T cut. Shall I post you a little tin
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
hi malcolm i still owe you for the last tin you sent me, but now it's gone :( if you are feeling generous then please do
I will buy a tin on Wednesday and you can send me a jar of mustard sill :D or lök (onion)
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
i'm happy to do so malcolm, drop me a mail at anyweb AT gmail DOT com with your address and i'll send it to you, tell me exactly what you want ok ?
cheers
I will Email you now niall,,, I will see what the T cut cost, I think some tubes of "Kalle's caviar" would be easier.
Please just Email me and we can do it off line :D
Made_in_Stuttgart
W211 E320 CDI
About 2 minutes :)
I too have the Bosch and shan't be buying them again. They used to make a queer noise and are scratched to buggery (totally clean screen). I intend on buying from Mercedes directly next time. Or maybe Halfords as television suggests.
