W211 headlight wash
alan782
Poole
E320 cdi (211) avantgard estate zzr1400(2012)
Happy Easter all. The headlight wash jets do not work, does anyone know where the fuse is? Also while i have your attention how do i get to the rear n/s fog lamp lamp.oh i have a w211 320 cdi 53 estate. Thanks.
See what I can do after a little food.
You get to the fog lamp by removing the front section of the wheel arch liner
alan782
alan782
Poole
Thanks Malcolm, Enjoy your meal, although at 33,500 posts i didnt think you had time to eat, drink or sleep!! I am a bit confused however as to how i get to the REAR fog lamp via the wheel arch?? Cheers Alan.
All will become clear later, :wink::D
alan782
alan782
Poole
You eaten already!! You will get indigestion. Why cant i put the little smileys in?
alan782
alan782
Poole
Yes it is in the tail gate, but do i have to take the interior trim out to get to the cluster or can i remove it from the outside? Thanks Alan. Also Sam while i have your attention When are you supposed to change the fuel filter on a 53 320 cdi (70,000)ish I looked at mine this afternoon and there was fuel all around it but no obvious leaks. I tightend the hoses but wonderd if the filters themselvs let go?
I have sent you 3 on the rear washer that of no use to you what so ever, the wine was nice and I will try again to do better in the morning:(;):confused:
alan782
alan782
Poole
Nice wine and you still spell better than me. What about the Food or was it just a liquid dinner??
No the meal all went wrong, just like the things I sent you.
Believe me my spell checker is working overtime, just like my head.
You do know that your headlamp washers only work when the headlamps are turned on
alan782
alan782
Poole
I have tried all combinations to try to get it to work but to no avial! So i am now of the mind it must be a fuse. Oh and morning.:D
No fuse as such for this,,there are 3 combinations of fuses
Up to 03, 03-05 a nd 05 on
The headlamp washer is a CAN operated thing, and uses transistorized relay M5/1 in the front box
I will send you an over view
Good you had your Email address activated, it will make sense once you see the layout
alan782
alan782
Poole
Thank you very much, its malcom to the rescue again.:D:D
I would test the pump first I think
