04 W211 E Class, the horn fuse keeps blowing, I have a short to ground on the yellow wire at the horn with the horn disconnected, anyone seen this before before I start looking?
Ok I have got it working without blowing the fuse, I traced the yellow wire from the horn to the fuse box under the bonnet, it plugged in under the fuses and there was another yellow wire on the same spade, this was the shorted wire, I cut this wire and the fault cleared, the horn works and nothing else seems to have stopped working, if anyone can tell me where this wire goes maybe I can find the short.
