moveover
- Sep 11, 2021
- W211 E220 CDI 2004
I know some similar problems have been posted here before but i'm not sure that this is the same issue. I have a E220 CDi 2004. When I purchased it a few months ago it had a number of faults one of which was and still is that sometimes it won't accelerate / kickdown and slows down up hill. Pull over switch on and of and it's ok for a few miles. It was showing a transmission control module fault and so gearbox reluctor plate changed, that code sorted. Also MAP sensor fault, also changed. However still have this acceleration issue. I have checked the EGR value, it's almost new and seems to be working. The current error code is 2527-4 check component Y27/9 left egr positioner signal line is interrupted. On the live date i'm getting a low boost pressure reading.
