W211 Rain Sensing Wipers
rjm900
London
E500 Avantgarde
As of this morning they don't work. And it's raining!
If I press 'screenwash' the washer washes and the wipers wipe twice as usual but they won't wipe on any of the other settings. Is this a relay/fuse issue or another of the inexplicable electronic glitches which seem to be standard issue on this model? Any thoughts gratefully accepted...
Hello and welcome,could you pop up the next 3 numbers after 211 and the year of the car please
R
rjm900
London
E500 Avantgarde
Thanks TV.
070 follow 211 and the car's from Feb 2003.
The wiper on your car is controlled from the N10/1 SAM and is fused from F57 rated at 15 amps in the front fuse box under the bonnet
Cole@MBS
www.mbssouthampton.co.uk
SAM only gets its signals from the rain sensor, if thats not sending anything then that my first port of call! fuse is ok because as he said, the wipers work on a wash cycle!
This means that it is the old problem the stalk, what says you
Cole@MBS
Stalk Malc? the Sam receives the signals from the rain sensor, that in-turn puts the wipers on, if the SAM isn't receiving any signals it will just work as a normal system!
So it is the stalk then that is not giving the signals, though the rain sensor is not anyway, apart from the standard sweep at start up its all dead
R
rjm900
London
E500 Avantgarde
Thanks guys...As it's dark & wet outside I'll check fuses tomorrow.
R
rjm900
London
E500 Avantgarde
You're right, Malcolm...except those awfully nice people at Temple Fortune now call the stalk a "combination switch" (they just go sometimes, sir...) and will charge £202. Indicate gently...
That is not too bad is it, you never know what life the combination switch had before you bought the car, pleased that you are fixed up
