Morning all,
I've had a brake issue, which I have now rectified .... but not solved ! Was hoping someone might be able to help.
Issue - After disc & pad replacement on rears, calipers binding on due to pistons not retracting properly after braking.
Rectification- replaced calipers.
The calipers worked fine with the old pads no issues, however the discs were shot & pads were wafer thin.
I assumed the worst & as I was short on time, I replaced the calipers.
I've since stripped the removed the old calipers with the intention of rebuilding, but can't see the issue. The caliper bore looks to be free from any corrosion/damage/debris. The pistons are ceramic and so are free from corrosion.
But the pistons will only slide nicely into the caliper about 3/4 way before jamming
I've used a vernier on the pistons & can't see any out of roundness/difference in diameter etc
I seem to remember reading someone had a buildup of brake fluid residue on their pistons and had used emery cloth to sand them down ? Couldn't find that thread though
Any ideas
Any ideas
