W211 rear door inner lock issue?
DSB SL AMG
Cheshire
300SL (R129 1992 Pre-Facelift), Volvo V70 D5 SE Auto
Hi All,
The REAR door RHS (drivers side) cannot be opened from inside the car, i thought at first child lock however w211 do not have child locks...
After searching the net i viewed the same problem raised on other forums on same year W211 (2004) model, same side....stating possible cause inner door handle cable detachment?
Any comments appreciated...
Thanks.
DSB.
I can send you the door card removal instructions so you can do it safely
DSB SL AMG
DSB SL AMG
Cheshire
Thanks Malc...my local indie would remove it...do you think the cause would be possible cable detachment?
mersum1es
Finland
Hi All,
Edit: checked mine, I have child locks! That button I first called, is for windows only I think...
It has to be,, nothing much else to it all:D at the worst some thing may have broken on the handle, but all minor stuff
DSB SL AMG
DSB SL AMG
Cheshire
mersum1es
Finland
I have a switch in 'normal' place where child lock switch normally is, edge of the door near the lock lid...
edit: in that last post, someone states he has them also... only I have it above the lid
DSB SL AMG
DSB SL AMG
Cheshire
Thanks for info...i found this on net
Rear child-proof locks
The child-proof locks on the rear doors enable you to secure each door individually. If a door has been secured:
you will not be able to open it from the inside
you will be able to open it from the outside, provided the vehicle is not locked (the locking knobs in the doors are up)
so where exactly is this switch, does it push in? push up? anyone got a pic or illustration?
If you open the door is not the switch in the end of the door, a little lever that slides up or down
Alps
london\Essex
2019 E63s S213, SOLD - 2013 Weistec E63 AMG, SOLD - 2004 E55 (x2)
yep little black switch edge of the door, i use them all the time with my two in the back.
DSB SL AMG
DSB SL AMG
Cheshire
Hi all,
Thanks for all your comments...yep found the switch, unfortunately it has not solved the issue...the inner door handle is very loose when you pull it (no tension), i strongly suspect cable detached / broken, needs door case off which will be done next time at local indie, will let you know update!
Cheers,
David.
Alps
london\Essex
ok, does sound like the handle cable mate.
door card is easily removed, take out the ashtray first and unplug the connectors esp the ribbon cable one before you start as they easily rip off and its £40ish for a new ribbon cable loom. the rest is fairly straightforward.
DSB SL AMG
DSB SL AMG
Cheshire
Update:-
Had car into my local indie today (MB Tech)....door casing off, cable was detached, re-attached...previous owner had rear class tints fitted so maybe they had disturbed something....anyway all now OK:D
Cheers,
DSB.
