w211/s211 power steering fluid
Terrykal
Hertfordshire
C219 cls55 amg
Hi to all,
I recently purchased my new s211 e320 cdi and I am trying to fix all the little problems that the car came with. OM642 engine if that makes a difference.
I want to change the power steering fluid, can anyone advise the code or part number?
there is no issues with the steering system but I am guessing that it has never been changed and I personally cannot live with this :p
I would guess it will be similar with other models too like the c219 and its p/n A001989240310 but I want a second opinion, thanks.
Hi to all,
If you refer to the owners manual it should tell you.
onefortheroad
uk.
Old style was red same as atf. The newer type is central hydraulic fluid. The type I bought was more light green than yellow tbh.
Terrykal
Terrykal
Hertfordshire
C219 cls55 amg
Yes I remember that my CLS c219 had the green fluid in it (it was almost black) and when I changed it I purchased the A001989240310 which is green again.
This one has a yellowish colour.
Thanks again.
Terrykal
Terrykal
Hertfordshire
C219 cls55 amg
And there we have it...
Very interesting, thank you.
Thing is that my yellowish fluid is much more bright and also I can find some power steering fluids for Mercs in yellow colour (if not mistaken oem p/n ends in ...313) and also these have made me bit more confused.
Will try to take a photo of the fluid tomorrow.
Terrykal
Terrykal
Hertfordshire
C219 cls55 amg
Good advice but unfortunately I don't have an owner's manual. Only service book.
This is why I opened this subject in case an owner with same specs model could answer it to me via his manual.
I know there is a link with all Mercedes specs fluids and I will try find it too.
Terrykal
Terrykal
Hertfordshire
C219 cls55 amg
To my research and my understanding till now there are two possible specs, mb342.0 or mb345.0.
First is equal to CHF 7.2 if I recall it correctly and second one is CHF 11s.
I have found the CHF 11s mainly as green but I also found it in yellow/golden colour, is it possible? If that's true then what I see as a very bright yellow in my tank then it can be CHF 11s specs so I could change it with same specs but green colour.
Any advice welcome
