W211 Xenon beam very low - axle height sensors working. Any ideas?
MJJ
Wiltshire
'09 S211 E220 Cdi manual - 216k miles and counting
Afternoon all,
Sometime in the last couple of weeks, the headlamp aim on my 2009 E220 estate (with Xenons) has started pointing very low. The lights do their normal up/down travel validation routine on start-up, then set themselves to a very low aim - meaning only 3-4 metres in front on the car are properly illuminated.
What I have checked:
- The bulbs are securely seated in their sockets as normal.
- The headlight assemblies themselves are both securely, and correctly mounted.
- Both front and rear axle ride height sensors appear to be mounted correctly compared to photos on the web, and nothing is mechanically broken.
- Looking at Live Data on Carsoft, the ride height sensor voltage changes (in what seems a sensible, correct way to me) when the ride height of the car changes.
- There are no error codes stored anywhere that I can see related to headlights.
- Carsoft displays a suspension compression value in millimeters as part of live data, but I don't know where it gets this from. This mm value seems very wrong to me, reading 31mm compression (31mm front, 4mm rear) when the car is sitting level and static,
- This same Carsoft mm measurement also changes in the opposite way to expected on both axle sensors - i.e. compressing the suspension physically by pushing down on the corner *reduces* the compression value in mm. The voltage change seems sensible and linear, just not the mm equivalent.
Anyone got any ideas?
Martin.
Maybe the sensor arms are sticking with dirt/lack of grease ?
Maybe try a silicone grease you can spray in to the arms/ball joints and other tight connections .
Maybe the rear sensor arm is broken ? It is quite hard to see properly
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
I had an MOT fail in my previous E55 for the same fault.
I took it to my local Mercedes specialist who recalibrated the headlight/dip beam aim using Star.
It was fine afterwards
MJJ
MJJ
Wiltshire
Thanks all. I think I may have to do as @AMGeed says and get it reset on Star.
Very puzzled as to why it suddenly decides to do this, particularly after 211,000 miles! I did manually select the continent driving levers a few weeks back as I drove down to Portugal, but the lights were fine immediately after the change each way. Very odd.
I have checked the free movement of both ride height sensors, and can see the voltage changing as I would expect in Carsoft live data. I am pretty confident they are both operating correctly, though I don’t know if they are reading the correct voltage level at static ride height.
Martin.
