MFK
- Sep 30, 2016
- Location
- Dublin
- E200 CDI / 2011 / W212
Broke a front coil spring and replaced the two of them. Changed brake pads at the same time. On hard braking the car is pulling uneven (to the left). It is not a jerk of the steering wheel but more like front left is biting causes the back to move out to the right if that makes sense.. There is no skidding. Any ideas what could be issue? All bushes etc seem ok.
I haven't inspected rear brakes yet. If I need to replace rear pads do you need to have diagnostic kit to wind back the caliper piston on this or is it standard.
When the spring broke it damaged the inside wall of the tyre so I replaced two front tyres as well. I haven't had 4 wheel alignment done since doing springs but plan to. Could the braking issue be related to this?
Appreciate any advice.
