mikes venture
- Mar 13, 2022
- w212 CDI 2013
Replaced turbo in May 2021 as it was leaking due to DPF issue was fine until October .Turbo actuator failed, drove 3 weeks on no turbo power. Fitted actuator, black smoke started. Checked the actuator many Times was told it's fine. Checked DPF, Injectors,EGR was checked and said to be clean. Changed rocker cover breather valve as i was told there was too much pressure and it was causing oil in turbo intake and oil coming out of the compressor hose as well. Black smoke when under hard acceleration, no smoke when pedal is pushed slowly. any guesses ? Are we looking at turbo reconditioning?
