W212 cooling fan staying on
Big Mo
E Class w212 350 Cdi
hello everyone
My e350cdi today. Fan staying on while driving. Engine temp is ok. Coolant level ok.
Anyone experienced this?
malcolm E53 AMG
Probably doing a DPF regeneration which on a very hot day can bring the fan on or the fan sensor is faulty
Big Mo
Big Mo
It was trying to do a regen as it goes. I’ll give her a belt on the m25 late night when she is cooler and see how she goes.
Cheers Malcolm.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
On my previous car, it was doing a regen as I finished a long journey. I was in France and the outside temperature was 30°C+ and the fan ran for a good ten minutes after I turned the engine off! I did wonder what that would do to the battery but no problems.
Big Mo
Big Mo
Thanks for reply! Regards
Big Mo
Big Mo
Sorted! Air con sensor and air con also topped up. Indy also found oil leak. 642 cooler issue so that’s a grand but hey!
Yes low gas pressure causes the fans to run. Had the same on my 129.
Big Mo
Big Mo
I am used to these quirks having been a Saab owner previously!
I was too!
Blisteringly quick (remapped, bigger turbo and bigger injectors) but the most unreliable car I've had.
Pity as in every other way it was really nice to drive.
www.W140.co.uk&www.r129.co
