W212 E220 DPF P244A7A and P244A00 Problems
clineng
w123,w124,w126
Looking for inspiration or experience to point me in the right direction
Have a 2012 E220 CDi which is in limp and throwing up the P244A7A (Pressure differential in DPF is too low. Leakage or defective seal detected) and P244A00 (the pressure differential in the DPF is too low)
Differential pressure sensor changed, reset on launch.....lasted about 10 miles. Was a smell of exhaust gases so found leak on exhaust where exhaust meets DPF/cat. Resealed and reset on launch. Still goes into limp as soon as under load. DPF showing almost empty. Any pointers on next things to look at.
Thanks in advance.
Bemajor7
Mercedes
Hi going through same issue, please say you managed to fix the issue, my heads going crazy
CowleyStJames
Oxford
Mercedes-Benz E63s, Old knackered G wagon
Thanks in advance.
When my differential sensor was changed they had to manually start a regen cycle of the dpf. Only after this did the fault code clear
ssheikh93
London
W213 E220d
Do you know what percentage your dpf is at. Could be due to high soot and Ash
onefortheroad
uk.
The sensor may require the codes to be erased and adapted ,otherwise old values are stored.
Pcurtis64
C class 2012 c220
Hi got the same problem on my 12 plate c220 cdi flushed out dpf loads of muck came out cleared code went for drive eml back on after about 10 miles when engine gets up to temperature.
Any pointers on what to do next would be very much appreciated as its starting to fry my brain
Many thanks in advance
Mr Greedy
Leicestershire
E350/2011/OM642 265bhp
How long have you had the car? Has the DPF been definitely doing a regen previously? Have you been able to verify this via EGT temperature or activation of the rear heated screen (without activation via the centre console button)?
Is it possible the DPF has been gutted, and a service (particularly at Mercedes) has reprogrammed the ECU via STAR update and therefore removed coding that has been placed on the car to ignore the missing DPF?
Failing that, it sounds from the error like you need to make sure all the seals from the turbo down to the end of the exhaust pipe are 100% sound, but I'll admit this is a guess.
Pcurtis64
C class 2012 c220
Thanks for quick reply I have had car from December 2019 couldn't tell if it's been doing a regen car ran great for nearly a year then eml came on took it to indie scan said dpf 400% mech said likely the dpf sensor so replaced it day later eml back on took it back said he forgot to reset OK for another day then eml back so decided to do it myself started looking into it then my gearbox packed up turned out to be the oil cooler leaking so I have now sorted that so back to original dpf problem now have flushed it out on car confident it's clean enough you think it's fixed then eml back read loads about it but nobody comes up with a fix. sorry for long winded reply will try your advice on checking exhaust seals and get back with results many thanks
Pcurtis64
C class 2012 c220
Hi got same issue and code with leak or seal did you manage to sort yours out, got any pointers sure does your head chasing it.
Thanks in advance
Paul
