W212 E350 Gear changes
rdmstewa
Wakefield, West Yorks
2004 W203 C180K, 2013 W212 E350cdI, 1976 Triumph 2500S Estate
Hi folks
I've found that when changing down from 5 to 4, usually when going up a hill there's a pronounced "jerk". It doesn't happen with other changes, just this one. Before I had this vehicle I had an E350 coupe, same engine and box and this tended to do that as well. Could it be that this is a characteristic of the 7G tronic box?
Thoughts appreciated!
Cheers
Malc
Whats the cars mileage , when was the last gearbox atf and filter change , when is the next one due ?
Any fault codes stored on the car ?
rdmstewa
rdmstewa
Mileage is 67k, atf etc. changed at 40k. Car's going into local indy on Wednesday, I'll get them to check STAR.
Many thanks
Many thanks
Good luck , let us know how you get on .
DSK
CLS 320 CDI, S350 Bluetec
Is this when you are changing manually?
Is this under any load or going up/downhill?
I have the 7g in an S350 and a CLS320 and have not noticed what you describe despite using the gears manually going down and up including 5th and 4th.
rdmstewa
rdmstewa
I notice it when going up a hill in drive - in 5th, car realises it needs 4th and the change down is noticeable - something of a "snatch" - not that smooth.
