W212 Wiper delay
Beemer2
South Lanarkshire
2014 E250 petrol W212
I find the wiper delay system frustrating in my 2011 E250 W212. It offers two positions of auto wipe but no option to select a fixed time delay. The auto wipe is erratic as sometimes in any of the two settings it fails to clear the screen for up to five seconds even when there is significant rain-spots lying.
Has there ever been a software update to this system or even a mod that reverts to the traditional timed method?
Ian
The first postilion is an auto wipe when rain is detected on the screen, the second is the same but speed related I think, in the event of a fault in the light sensor the system reverts to intermittent wipe.
I have noticed that sometimes the screen has to get quite wet before the wipers kick in, a good clean on the glass with T cut has improved mine
brandwooddixon
Wolverhampton
S63 Coupe 2014
But not over the sensor :)
The water needs to bead on the area of glass over the rain sensor.
daveyjp
B160 SE Blue Efficiency
The MB system is frustrating so I never use the auto setting.
Instead I use an ample coating of Rainex (actually the Turtlewax version as its cheaper!) - it's my job for sometime today prior to the 1000+ miles I will be doing over the next couple of weeks. Once on you can forget needing any wipers above about 40mph.
daveyjp
I've used Rainex for 20+ years and never had a problem. You do need to trust the product though and when its raining let it do its thing, don't have wipers going constantly as this causes it to smear.
You do need to apply it correctly though. I clean the glass with Mer window cleaner then apply two coats of Rainex, after that the wipers are only required very occasionally.
Beemer2
Beemer2
South Lanarkshire
I bought Rainex 20 years ago. Used it twice and was not happy with the result. A further result is that the bottle is still in my garage.
I should not have to use such a product to fix a problem introduced by MB. I will try using "Intensive Screen Clean" which I already have but what was wrong with the selectable timed interval method?
Ian
I am sure that you have auto rain sensing wipers
hawk20
ML250 BlueTEC Sport
Ian
Nothing but I suspect most find the auto wipers a step forward. I like the system.
Beemer2
Beemer2
South Lanarkshire
I know that I have them, its just that their operation is erratic especially when it is leaving the screen wet too long.
Ian
Ian
I must say that I have noticed the same problem in the last 2 weeks, but never before and never on the 230 SL. With the CL I have to turn the switch when in slow moving traffic.
I will take a look to see if anything can be altered on the timing
Beemer2
Beemer2
South Lanarkshire
I would rather the bias was towards too early/much wiping than too little. I have even experienced a wipe-delay start when passing a spraying truck such that I had to quickly select the continuous wipe position when halfway along the truck.
I'm hoping that this must be software programmable.
Ian
cliveyboy8
Ashford, Kent
2008 C320 CDi. 1985 230E. 2005 Westfield 1800 SEiW.
Ian
Just press the end of the stalk to getone sweep of the wipers. Simples!
True, a light touch would not operate the washers, sounds good to me :D
www.W140.co.uk&www.r129.co
