W213 convertible 2018 boot wont open
SPICEDJ
w213 cab
can you help need a real expert here , ive been having issues with my eclass 2018 220 convetable, ive been told theres a leak and some components are damaged and i cant get the boot to open with the key fob or switch inside
is there a way to manually open the boot from inside the boot. there's no catch or key hole
Hello and welcome,
There should be a keyhole next to the opening handle underneath the boot lip - use the metal key from your key fob and turn it 90'
You might need to clean / lubricate the keyhole if you've not used it before
SPICEDJ
w213 cab
Hello and welcome,
i have a 2018 e class cabrolet there is no key hole its been removed on this version it seems, does anyone know of a way to open it from the inside of the boot, i took it to Mercedes and they found water in the boot ???? they say some components have been damaged and it will cost me £2500 to fix it, i'm stunned i bought it from them and they are offering no help whatsoever.
car has been giving problems since i had it this is just the latest , can anyone explain how to open the boot?
You don't have the boot lock separator switch in the glove box enabled do you?
SPICEDJ
w213 cab
There isn't one in there it says there's one in the manual but it's not there
SPICEDJ
w213 cab
I can't open the boot is there a way I can find a wiring diagram for the car I have?
