DIYDave
- May 31, 2022
- 2017 E220d AMG Line Estate W213
Hi, I’ve got the common fault of sat nav thinking it is in Germany & have decided I’m going to have a go at replacing the GPS antenna myself. Is it located in the drivers door mirror in a UK car? I’m thinking I might need to remove the door card/panel to actually plug the replacement antenna in. Any advice or links to internet resources which will help me with this aspect will be very much appreciated? I’m going to source the antenna from the internet - am I best buying an expensive Mercedes antenna or will a non Mercedes antenna work equally as well? Thanks, David
