Anything with MB 229.51 approval.Hi guys, was wondering what's the best brand of oil for the W213 E class 2.0 diesel. Many thanks.
Hmm, you see I'm a bit confused since the Mercedes website says " MB229.71 ", was wondering if it's a big deal if I use 229.51 instead of .71?Anything with MB 229.51 approval.
Was wondering what was happening when I read in another article about an 229.81 spec. thought that it had to be a mistake......so 229.52 is not the highest nr...229.51 and .52 are normally 5W30 , 229.71 is a 0W20 .
Each higher number pushes the fuel economy performance .
Engines are designed to run on a particular spec of oil.Was wondering what was happening when I read in another article about an 229.81 spec. thought that it had to be a mistake......so 229.52 is not the highest nr...![]()
