P
psr
My phone reception on the COMAND system gradually got worse and then went altogether. Does anyone know where I should start looking for the problem?
I dont believe that statement, the Command and Telephone/CD on the 220 all work on the D2B. The D2B is a fibre optic system and it links the above three items. The fibre optic cables can be easily damaged, also any problem in these three units can cause a fault in the other two. So the rule of thumb is if one system is not working OK then are the other two systems OK? That would be the first question. If the other two systems are working ok then he may have a valid point. But its not the only answer. Sorry if this post confuses you. On this subject I could go on all blooming night, its a good one to work on.Thank you. It's WDB2200752A151....
The manager in the Mercedes dealer said it could be an antenna amplifier in the COMAND unit. Not so sure about that.
MALCOLM, hallo and wake up, did you not read the post correctly? I never mentioned OBDII. Im talking about the D2B, and this system is nothing whatsoever to do with OBDIIEric, once again the 0DB11 is only a communication system between the modules and has nothing to do with the working of the individual modules. There are no telephone signals in the can bus as such.
No, not so, you may not get any such command answers. Do your homework and youll find the answer.So I put a 0 in front of the D2B but it still makes no difference, this is a wake up closed circuit and has nothing to do with the failing of a component in the chain. D2B is a networking communication system, if the net working was not working, a message would come up on the command saying " not communicating with the phone" if the optics were damaged other parts of the chain would not work. The optics loop through each device.
It's only the phone reception that doesn't work and it went away gradually, so I suppose I have some kind of antenna problem.
I haven't managed to get into the parcel shelf area yet - doesn't look as straightforward as an average car, but do you know what C pillar this amplifier might be in and how I should test it? If I bypassed it would I still get some weak reception?
Thank you.
