"The first thing you will need to do is remove the mirror housing. If you look on the bottom between the housing and the mirror you will see a clip holding the housing to the mirror assembly. Gently pry the clip with a flat screw driver and pull the housing off. Once the housing is removed, it will expose the mirror assembly and one screw clearly visible and accessible. Using a T-20 screw driver, remove that screw then turn ignition on and fold the mirror. Once mirror is folded, you should be able to see the other two screws. Remove those and the whole assembly comes off. Be careful not to let it fall off and scratch you paint"
