Hi all,
Could somebody please tell me where the ECU for a 2001 W220 is located.
Thanks in advance
Hi Malcolm,
The tale is quite a long one, so here goes.
The car is a 2001 reg S320 CDI
Before Christmas, my heater blower fan stopped working, the fault being that water had entered the chassis via an air vent. I subsequently found out that this was a problem with this model, and took it to the dealer to have the recall done (I also had the heater blower replaced).
I then experienced problems with starting the car - namely that it would not start after a cold spell and would throw up spurious warning messages on the dash (ESP, ECP Bas etc), unless I jump started it. This pointed to a faulty battery - which I changed, but the same problem is occuring.
I took it back to the dealer, who plugged it into their diagnostic kit, and was told that there was a problem with a contact somewhere, which was probably caused by the original leak.
Upon inspection, I found that the passenger footwell (where the blower fan is located) was full of water close to a cable tray which is located at the side of the footwell.
I would like to know if there are any ECU's in this area, so that I can inspect the connection, as MB estimate that it would cost over 500 GBP in labour alone to look at the fault, which they admit may or may not be the cause of my starting problems.
I hope that this is sufficient information for you.
Regards,
Roy
